Manual Design and Adjustment of Custom Print Report Templates
Designing Templates
Adjusting Templates
Image Upload Fields
1. Single-Select Image Upload
After downloading the default template, you need to manually adjust the template's field syntax. Add IMG:html after the syntax for the Image Upload field to ensure the images in the field output correctly.
Note: If "Max Height" and "Max Width" are not specified, the default image output is "300px" for both dimensions. If specified, the image will be displayed according to the defined settings.
Signature and Barcode Fields
Free Text Fields
